DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Tue Aug 02, 2005 11:49 am
the 248/248 set up is definately advantagous if you set up all your other breathing and ignition timing to the top end. 248s easily pull hard all the way til at least 6500, but if you really need the extra 500 rpm you can actually use it a little, very little.
You'll notice more top end gain if you have an actual short ram intake. Not one you can buy, but the homemade diy kind that you route to where the battery used to be, but if its in a truck i'm sure you'll figure out what to do. also, it doesnt hurt to run a little more ignition advance if you dont burn crappy gas.
Everyone knows that the intake manifold sucks for high rpm power delivery, but no one ever shortens the intake tubing for a much easier "kinda-fix" If you go too short with the tube you'll notice you're making the most power where you cant even rev, so gradually lengthing it until you get the powerband to where you want is helpful to gain top end. You'll want to use a mushroom filter and cram it as tight against the inner fender as you can. and as long as you are just making stuff up, cut out the metal between the filter and the headlight, and make up a quick cold air box, this easily will net more horspower than any off the shelf intake
