s13 caliper swap to z32
celica3sgte94
Car: 99 g20 89 240sx hb with 95ka24de
i have a 89 hatch with no ASB and i tried to put a s13 caliper on with ASB since the caliper was bigger but to me it wouldnt bolt on is it just me or its not ment to be a blot on and since the the ASB s13 caliper seem not to bolt on so will it be the same if i tried to put the z32 on or will it bolt right on just my miss??
180fan
Car: 89 fastback
why are you trying to put on abs calipers on an non-abs car?
celica3sgte94
cause the abs calipers are bigger than the non abs calipers
180fan
Car: 89 fastback
Doubt they'll make that much of a difference seriously.
Vr6WantSr20det
It wouldn't bolt to the spindle/Carrier bolts? It might be because the ABS and NON-ABS rotors are different.
celica3sgte94
no no no i want to put the z32 calipers on just wanted to know if they will fit or not since the abs seemed like it wouldnt fit
180fan
Car: 89 fastback
don't see why they wouldn't if everything else is made for the z calipers too.
celica3sgte94
so what do i need to do the sawp just the calipers and rotors or do i need other stuffs???
180wanabe
Car: 90 240 hatch with 91 dual cam
you will also need conversion lines. spl parts has some nice ones or you can hit up 240sx motoring for some.
celica3sgte94
so it is a direct bot on right? only reason why i ask this is cause when i was tryin for the abs calipers it looked like it didnt bolt on
180fan
Car: 89 fastback
you need to do a search for the details on this. at 118 posts, there is no excuse for not searching this question.
