Hi All, Basically i bought an s13 8 months ago, and due to work commitments i havent had time to get her running. So while i have a few days off, i decided to get cracking on it.
The engine:
Mahle Pistonsstage 3 chipT28 Turbo300zx MAF?Big FMICLarger injectors
As it stands, the car will start, but will only idle. If i try and rev it atall then it dies. I can however rev it when it first starts, up to about 4-5000 then it dies instantly and will barely idle. It sounds great on idle,
I have changed the plugs, checked the cambelt position, but still the same problems! Im wondering wether the vacuum piping etc is correct? is there anywhere i can get diagrams to check? or would that even be the cause?
Any help would be greatly appreciated as i am new to these engines, and it so badly needs to be taken out for a thrash!
Cheers,
