i am still quite a newbie to the tuning world so please excuse any dumb questions
my problem is when i enter hot running conditions, it floods the engine when i let it go down to idle it doesnt catch idle and just dies, and the plugs will be wet afterwards...my afr measured on aem wideband is 14,4-14,7(idle-2800 rpm) when the flooding occurs and the lambda reads 0,99-1,00 so i dont get how it floods...
theres is an idle problem when heating up aswell if i give it a little gas and then let it come to idle it will fall to 500 rpm then catch on again and go at a steady 900 rpm at idle gets worse as it warms up to the point of flooding, and of course i cant really drive it anywhere as it wont fire backup after this happends.
injectors are fine it will hold fuel pressure at 3,5 bar for 10 min after i turn off the car if i clam the fuel return line so they shouldnt be leaky
the engine has been rebuild, so compression, HG trouble and so on isnt an option
CAS splines are fine
new coils and plugs, and spark looks fine (battery is showing 10,5+ volts when cranking)
my mods are:
gt2860rs
444 gtr injectors
z32 afm
hks filter
apex FMIC
apex flywheel
nistune
adjustable FPR (set to 37 psi at idle)
oil cooler
wallbro pump
engine has been honed, acid bathed new bearings all round valves checked and new rings and pistons. new gaskets and seals all round
any advice or ideas would be greatly appreciated
