s13 brake upgrade
xero1
Car: 08 Altima Coupe
i'm planning on doing a z32 rear brake up grade to my 89 240. Do i need any special parts or does every thing bolt up?
hybrid_flyer
Car: 95 240sx SE wrecked....89 240 coupe now
yes you will need brackets for the front calipers, and i would reccomend changing to a 5 lug hub too. the backs will mount right up. But you will have no parking brake if you change the rears, but you can fix that too
xero1
what do i need to make the rear e-brake work?
C-Kwik
xero1 wrote:what do i need to make the rear e-brake work?
The entire drum brake assembly. I believe the hardware will bolt to the S13 rear uprights. You'll likely need the e-brake cable as well.
Exar-Kun
Car: 2005 350Z
you'll have to splice the e-brake cable..which is touchy at best. Re-routing it is a PITA also. You could try and find someone who can custom make one...that'd be your best bet. Not sure if anyone's made this part for bolt-p purposes yet.
-Chet
spider_slayer
Car: S14 240SX
S13 240SX
just stick with the fronts. the back as everyone else has stated is a PITA. with jsut front z32 calipers your bias is still ~75%-25%. not ideal but pretty good.
usdm_180sx
Car: 1993 Nissan 240SX base S13
Performance Nissan sells R33 Skyline e-brake cables. These fit perfectly. No splicing required
McRussellPants
Car: 92 240SX
S14SRPilot wrote:Performance Nissan sells R33 Skyline e-brake cables. These fit perfectly. No splicing required
