S13 Body question
DriftReadyS13
Car: 92 s13 w/ sr20
ok so i can pick this s13 up pretty cheap... i plan on using it as a project..
firwst thing is its an auto.. i want a 5 speed but will swap.. or atleast try to.. not too worried about that
now the thing i want to ask is the passenger side rear quater panel is pretty messed up.. what would be the easiest way to fix it ? or wouuld putting wide body rear fenders on be the easiet? thanks for ur input
lbreevesii
Car: S13 hatch LeMons project - Kaputzen!
BMW E30
haha that looks almost exactly like mine, only on the other side. Mine got into a fight with a mailbox...(previous owner)
Fixing the dents will be a PITA. I would recommend some widebody overfenders.
djidentity
Car: 1995 240 - KA24DE - 204k
Well you have a lot of options... Im all about preserving the original body style of a 240. In that case, you can find an old junked out one, maybe with some rust and a non damaged side, and harvest the metal. Sheet cutter, some fabrication, welding, sanding, priming and painting. Sounds like a b****, but ya know, it works a lot better and you def have something to show for it.
