Ghettokracker71 wrote:I pulled/pryed on it,with no luck.Whats a good way to remove it w/o causing damage to anything?However I did take out the blank plate under my headlight switch (plate for cruise control,I have a base model) and the only thing coming off the back of my dimmer switch is a bunch of wires with a plastic cover over them.
Sorry. This is what I should have said in the first place...gosh that'd be nice to get this **** fixed.
Thanks for your pateince.
O, that's "simple"
1) The switch is hooked in by two clips (think it's top and bottom side) on the switch itself. You should be able to feel around for it, depress the clip and it comes right out.
2) If it doesn't, you'll have to remove the whole bezel. Which is a lot of work if you haven't done it before:
reference
http://www.zilvia.net/installs...p.asp
And Asia989. Well, with my lights, the lights go intermittently on and off. I know it is a loose wire connection that is causing that, however, it takes forever to trace these damn wires, and even then, it gets confusing trying to find if it's loose, a short etc, because it will work sometimes for a while before anything happens.
If it is the radio, I have no clue, but I have heard that that happens alot with aftermarket installs. Try completely unplugging your stereo and see if the problem goes away.
hope that helps a lil bit
