S13 blktp into S14 auto ?? DVD ??
Beanstalk
Car: 89 240sx & 95 240sx
Hi to all my name is troy from columbia mo, and i`m new to this forum
So i have an 89` hatch with a blacktop sr running great and all but its rusty and so i bought an s14 auto for 1300 and want to swap my sr into it ok with this said i have a few ?`s
1) Will my clutch pedal assy. transfer from the s13 to the s14?
2) I bought a FMIC kit and radiator from CX racing on ebay will it transfer?
3) And lastly Will my wiring harness still be ok to use?
Any help will be awesome
Oh almost forgot and will my exhaust work it to was a kit???
Beanstalk
If anyone knows it would save me alot of hassle and does Drifting.com have there dvd up yet for the s14 swap?
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
The FMIC will bolt up but the others will need modded. IDK about the exhaust.
SR240SEX
Car: 91 240sx
1. Yes the pedal assy will work, no problem. However, you will need a S14 manual drive shaft, s13 will not work. Just cut the brake pedal, it's not worth the hassle to replace.
2. Intercooler should be no problem, but you will have to fab up some top mounts from the radiator.
3. The harness can be used, but will not just plug in, it will need to be rewired. There are many posts on how to do this.
I'm not 100% on the exhaust, but if memory serves me correct it will not be direct insall, but a muffler shop can make it work.
fast_s13
if you need a hand swapping everything over im close by... s14 wiring is a little differnt
