s13 blaktop ecu codes
g-man
Car: 1991 240SX
Did a search for the codes for the ecu on a s13 blacktop. I could not find any info. Does anyone have these codes or know where I can get them I would appreciate it.
Fenvy
Car: 2005 350Z Base 6MT
I know you dont have type x motor
so you have e15, if you really want to be sure you can kick your passenger side kick panel really hard and you will be able to expose the ecu
SpeedRacer1
Car: 1990 240SX, G35
Basically all S13 SR20DET's have the same fault codes...ECU fault codes
Long Flash - 0.6 seconds on (the first digit) Short Flash - 0.3 seconds on (the second digit) Long Gap - 2.1 seconds off (used between codes) Short Gap - 0.9 seconds off (used between digits)
There are two digits in each code. Count the long flashes, then the short flashes (only count how many times the light is ON) and you'll have a 2 digit code. These codes are covered in the service manual.
Code Meaning 11 - Camshaft Position Sensor 12 - Air Flow Meter 13 - Coolant Temperature Sensor 14 - Vehicle Speed Sensor 21 - Ignition Signal 25 - IACV - AAC Valve 26 - Boost Pressure Sensor 31 - ECM Fault 32 - Exhaust Gas Recirculation System 33 - Front EGO Sensor (O2-1 Sensor) 34 - Knock Sensor 35 - EGR Temperature Sensor 36 - EGR BPT Valve 37 - Closed Loop System 41 - Intake Air Temperature Sensor 43 - Throttle Position Sensor 54 - Signal from Auto Transmission 55 - Other Malfunction. CONSULT Terminal Required 63 - Cylinder 6 Misfire (?) 64 - Cylinder 5 Misfire (?) 65 - Cylinder 4 Misfire 66 - Cylinder 3 Misfire 67 - Cylinder 2 Misfire 68 - Cylinder 1 Misfire 71 - Random Misfire 72 - TW Catalyst System 76 - Fuel Injection System 77 - Rear EGO Sensor (O2-2) 82 - Crank Position Sensor 84 - Automatic Transmission Diagnostic Comms Line 95 - Crank Position Cog 98 - Coolant Temperature Sensor 103 - Park/Neutral Switch 105 - EGR Solenoid 111 - Inhibitor Switch 112 - Automatic Transmission Speed Sensor 113 - Automatic Transmission 1st Signal 114 - Automatic Transmission 2nd Signal 115 - Automatic Transmission 3rd Signal 116 - Automatic Transmission 4th Signal 118 - Automatic Transmission Shift Solenoid Valve A 121 - Automatic Transmission Shift Solenoid Valve B 123 - Automatic Transmission Overrun Clutch Solenoid Valve 124 - Automatic Transmission TOR Conv Solenoid Valve 125 - Automatic Transmission Line Pressure Solenoid 126 - Automatic Transmission Throttle Position Sensor 127 - Automatic Transmission Engine Speed Signal 128 - Automatic Transmission Fluid Temperature Sensor
from http://sr20det.nismo.org/srtech.htm
g-man
Car: 1991 240SX
Thanks for the info you guys are awesome!
Rican_Nick
i have a type x black top.. i am tryin to pull the codes form the ecu (j4) but it does not have the screw that most nissan vehicles have that allow u to pull the code.. anyone know how th hell to do this on the 97-98 s13 blacktops???
SpeedRacer1
The ECU is similar to the S14 and S15 ECU's. If I recall they run codes by watching the check engine light flash or running the consult. Basically its almost hopeless.
Rican_Nick
SpeedRacer1 wrote:The ECU is similar to the S14 and S15 ECU's. If I recall they run codes by watching the check engine light flash or running the consult. Basically its almost hopeless.
damn thats what i thought with the way wiring is done for the s13-sr swap will the check engine light work? i have never seen mine light up. Same thing for the Consult with the wiring thats done for the swap will the consult be able to read any ecu codes??
i am thinking the answer is NO to both.. but i just want to make sure.. i am gonna call my buddy at Nissan to see if we can get the conult to check.
thanks for your help.
SpeedRacer1
There are extra wires for the consult port, there was a thread floating around here on how to try and get them to run properly. I am unsure if any of the extra wires coming off the ECU wiring is for the engine light however.
