SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Tue Aug 03, 2004 5:24 pm
Its been awhile since I have done that wiring, but if I remember correctly, the two thick wires on the SR harness black with red stripe, and blue with red stripe should be spliced together before connecting it to the KA harness to the thick black with red stripe.
If I remember correctly, the thin blue wire with red stripe isnt even used.
For the O2 sensor, there is no corresponding wire on the KA harness, so what you do is splice it to and 12 volt source on the SR/KA harness. You can splice it to the thick wires if you want since they are 12 volt sources and you are already splicing them into the KA harness at the same time.
AC, I have no idea, but I would just splice both, you can try one and if the AC doesnt work try the other.
