nismotuner1 »
https://forums.nicoclub.com/nismotuner1-u94790.html
Tue Sep 15, 2009 8:27 am
so my car started to miss fire a couple weeks ago. only above 3000rpm. I first noticed this on the highway cruzing in 5th gear the tach was bouncing between 3000 and 3200 rpms. but that is the only way you can tell while driving it is very slight. if the car is parked and you hold the rpms at 3000 you hear a slight pop out the exhaust when the tach bounces. it does not do this under wot. I have checked timing 15 btdc, plugs,ecu (no codes). alternator is putting out 14 volts I added 2 chassis grounds and an engine ground due to the last time on the highway the temp gauge was bouncing when the tach was. so I thought is might be a ground/ voltage issue. I did this swap last summer and this is the only problem I have had with it so far. any input would be appreciated.
