S13 Blacktop into S14 AC Wiring
s14sleeper
Car: cars
Can anybody help me with this? I want to retain my AC -has anyone done this and what is required. Wiring diagram is greatly appreciated. Im researching now, as im getting ready to do the swap.
turbocarslut
Car: 1989 Nissan 240sx (hatch)
2011 BMW 535xi
I wish to know also.
s14sleeper
Car: cars
found some info at SRSWAP.com, under the FAQ-sr20det questions, there is a section for AC. i think thats where i got it from.
turbocarslut
2011 BMW 535xi
they dont have it there.
kineticniwa
it's in sr faqs at the top. click that and go down and click the air conditioning link.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
They haven't gotten it out yet. They say on the site that they will post it ASAP when they can. I'm still thinking about just using the SR compressor.
Structure240sx
havent done the swap but have researched it that adn KAT cant make up my mind. im pretty sure i read that the SR compressor will work but only 2 of the bolts will mount whcih is suppose to be enough. i read it from a guy Ralph Malendez's wesite on his 240
ItzGenX
It is the other way around. The SR compressor will mount perfectly, but you will need custom a/c line fittings. The KA compressor will fit on the same mounting bracket but only 2 holes will line up out of the 4, and the a/c lines will obviously fit onto the KA compressor.
pampadori
Car: 91 Nissan 240SX coupe
that last swap i did was a redtop into a 96 s14. the 96 ka compressor bolted on with all four bolts. the pulley was offset about 2-3mm instead of having a 4 ribbed belt, a 3 ripped belt would work. the stock k1 line hit the p/s tension adjuster. you have to bend them a bit. it can work. also, use the wire from the s14 chassis not the sr engine harrness wire. you'll see what i mean.shaun
ItzGenX
How did you get 4 bolts to fit? Is this only on S14 chassis? Also, I think you can fix the offset with washers or spacers.
pampadori
well, they just all four lined up. the off set i need is to move the pulley out. i guess adding some washers to the compressor under the pulley might work.shaun
creophus
Car: 240SX SE & 200SX
This is all great news as I am about to get the swap done...I live in FL and A/C is a must! Also, PS would be great too! Might make it easier for me when I autocross or drift!
