s13 black top just doesnt feel right
ralphie!
Car: 89`coupe with redtop sr and lots of goodies and a 92`hatch with rb25 and even more goodies
hey guy i searched on this. I cant really explain it but it just isnt pulling right.set ups13 black topfmicturbo xs bovka24e mafwalbro 255 fpopen elbow
I have pleny of friends with sr`s one with this exact same set up and my car just does not have the pick up it feels laggy. I cant really explain it. It doesnt doesnt have that get up and go. It has good power just is missing something. any help im wide open to suggestions.
oki_bum
Car: SR Powered 1990 240SX
can you give us a little more to go off of? Is it holding boost? Boost coming late?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Do you get a lot of black soot out of your exhaust? Sometimes with the higher capacity pump you'll get too much fuel, which can cut down your power. It could also be timing. Getting a fuel controller and a timing light for a tuning session can solve a whole bunch of performance issues.
GTS4-R
Car: my feet
check the ignition timing.....follow the FSM and DONT use the loop in the back....put the inductive pickup around the primaries to coil 1 OR use a makeshift wire from the coil to the plug and use that...follow the fsm BS with the revving and unplugging the TPS reset it to 15BTDC and lemme know how that works out....most likely thats ur prob
