S13 battery relocation *pic*
wcbjr
Car: KA24E / hatch
Here's a pic of my setup. 4 gauge from KnuKonceptz, and the only battery terminals I had at the time. I used a small battery because I did not want to drop the gas tank in order to bolt down the tray, and because I have very little power needs except for starting the car and running the engine.
The cable runs directly to the starter, then an 8 gauge for main power has been daisy-chained and run to the relays. I cut the old ground cable in the engine bay off, so there is only the cable that runs from the lower intake manifold to the battery tray.
wingFeather
Car: Current: 05 G35 Coupe
Previous: M35, M35 Sport, cube, J30, s13 sr20det, s13 rb20det, s14 zenki
Excellent work!
White Comet
Car: fc, s13 and mazda6, Sierra
a little thinner then what i'd use, but im sure it'll be fine
rocksteady_racer
Car: 90 240sx Hatchback (Manual - boosted soon KA24e)
Slightly off topic:
I got a full size optima yellow top in my trunk - in a battery box mounted to the floor like that. But I didn't put bolts under it I just threaded it in. Didn't work out to well - it ripped the ties right out of the chassis so now I'm going to weld a 1/4in plate of mild steel on top of the hole and weld thicker tie down bars into it and build the box around that.
But good job on yours :) I love trunk batteries - makes everything easier to wire and cleaner in my opinion.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
you should put it in a box man...#1 to protect the terminals from arcing on sumpin that may roll around on ya..#2..batterys make gasses if there not the sealed type like an optima....#3..if your in an accident you may have battery acid flying all over you and your car..just my thoughts..good luck
nissanman04
Car: '90 240SX, '95 Subaru Legacy
liquid_cool wrote:you should put it in a box man...#1 to protect the terminals from arcing on sumpin that may roll around on ya..#2..batterys make gasses if there not the sealed type like an optima....#3..if your in an accident you may have battery acid flying all over you and your car..just my thoughts..good luck
Looks like it might be a dry cell...if not, yeah, 2 and 3 are legitimate risks. Of course #1 is always a risk, but assuming the tie-down is good, there shouldn't be a problem.
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
I'd sure hate to get rear ended with my battery that close.
wcbjr
Car: KA24E / hatch
This car doesnt get much use, nothing to put in the trunk. Anyways, that is one reason that fuse is 1' away from the terminal.
The battery is sealed, no gasses or acid.
