Rin5 wrote:the funny thing about this is i did soooo much more and i have the same problem that i havent been able to check out cuz im very busy but its workin fine...
when i did my battery reloc. EVERYTHING was fine.but then silly me relocated the fusebox too...i think i mixed 2 wires cuz WTF nissan thanks for putting 2 purple wires with same AWG. one went to fuse one went to relay >_< i think i switched it cuz my car only turns off when i take out the FUEL PUMP fuse...that and i keep hearing one of the relays click alot
could you possibly show pics of your work?
I can try to get pics. I'm not sure its the battery relocation causing the problem. I ran a 2gauge battery cable from the stock location to the trunk. I connected the front together with big spade connectors and a bolt through the middle and then insulation around it. Then in the back I ran a 100amp fuse about 8inches from the battery.
The car starts up fine, everything charges fine no dimming of the lights.
I think my problem is in the wiring of the car. The car has sat since 2001 and there were nuts in the engine bay from a mouse. I swapped in my sr20 this past month and all the engine bay wires seemed fine. I am going to pull the dash out to see if something maybe wrong in the wiring. Basically going to check all of the wiring in the entire car.
I have a complete wiring harness from front to back of a car I stripped before this car so if I need to, I can reference that or use the harnesses.
If I take the SR harness completely out and lay it on the floor, when I turn the car to ON and then back off the power still stays on. I have to ground out the black/white wire on the ignition key harness for the power to cut off. I can here relays clicking to for the car to turn off and then the power goes off.
When the car is running, it's in safe mode and won't rev past 2500rpm and runs really rich, but from reading most say it's a MAF problem. So I have to check that out also.
Edit: But to understand how I did my battery relocation, I did exactly how the write up did in the link I provided above in my OP. I mean exactly except I used 2gauge battery cable from the NAPA store. I even have my ground in the same spot.
I tried removing anything out of the equation that would be causing my problem, and I know I followed this write up perfect.
