Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Jun 12, 2008 9:44 am
Is this a manual or auto trans?
Also, was this car a 5 speed swapped car?
If it was a stock 5 speed, test the reverse switch on the trans to make sure its working. If it is, then you need to check the wiring to make sure something isn't busted. If it's bad, replace it.
