S13 automatic seatbelts
djsilver
I'd like to find some conventional 3-point seatbelts for my '93 240sx and I'd like to know which compatible years/models to look for in the junk yard (i.e. S14, Altima, truck?) Anyone already have this info?
240marcuSX
Car: E34 525i
E46 M3
i got a manual passenger seatbelt off of a canadian 240 that i found in a junkyard, of course it bolted right in.
onosqv
Car: '92 240sx Vert
i believe the rear s14 seatbelts also work for the s13 front - don't quote me on that tho.
As for the canadian seat belts - yes they work, and there is a guy on zilvia.net selling a set or two every month since he is from Canada. Expect to pay anywhere between 100-200 dollars for this tho.
bruinbear714
240marcuSX wrote:i got a manual passenger seatbelt off of a canadian 240 that i found in a junkyard, of course it bolted right in.
That would be your best option. Direct swap.
240marcuSX
Car: E34 525i
E46 M3
$100-$200!!!! geez, i got mine for like $10, lol
slow s13
Car: cars, photo, music
s14 belts work I've done 2 cars with them now. I was looking at some altima belts in the junk yard and they looked they might work.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
if you dont mind a tad bit of ghetto-ness for you're already nasty stripped interior (by which i am refering to my own) you could just use the s13 rear seat belts. you'll figure out right away where everything goes. the only ghetto part about those seqat belts is that they want to constantly retract and they take a long time to pull out again, so here's where the ghetto part comes in: you get in and get the seatbelt comfortable to you, then tape around the seat belt at the retracting mechanism so it will not retract.
