I thought my problem was my S13 auto trans, but after replacing the AT, the same problem popped up.
Symptoms: S13 auto trans 'down shifts' on its own from OD to 3rd, and then to 2nd with a steady and light pressure on accelerator @ highway speeds, and speeds over 35 mph.
scenario:
240SX 's auto trans runs fine
1) I replace the alternator, I run the 240SX and then determine that FI #2 is dead.
2) mechanic agrees and mechanic replaces the #2 FI
3) 30 miles and two days after mechanic work, which is also about 50 miles after my alternator R&R, the auto trans goes into 'down shift' action. When down shifted, there is no power thru the auto trans and any more gas pedal only runs the revs way, way up.
If I sit quiet on gas pedal and trans will 'up shift' to OD. Then, in a few seconds same thing happens: 'down shift' for 3-5 seconds, and 'down shift' for 5-10 seconds and after 20 seconds it returns to Over Drive.
4) mechanic said not his doing ! ! ! I took the 240SX to an auto trans specialist. Honest shop. Said ATF was pink and odorless; we (shop and me) saw no shavings in AT pan after it was pulled/removed. AT shop had no idea what the exact problem was.
5) replaced 'bad' AT with known, good used AT. Outstanding results for the first few (25) miles!!
6) 30 miles after good ued AT was installed, and occurring the next day, the exact same symptoms. EXACT!!
I have the FSM at home, but nothing there I could find describes these symptoms.
The auto trans specialty shop said to rebuild the trans (obviously not the right diagnosis!!)
Would a NISSAN dealer be able to diagnose and PIN POINT the cause of the symptom. Accurately and correctly !! What equipment should they have to do this, other than a 'code reader'?? -Yes, I am showing a CHECK ENGINE LIGHT as I have for the past three years. Code was 32, EGR code. Couldn't find the problem, so light always on...
I know this is a technical question, sorry
Barry Burneskis
[email protected]
Modified by honeybus at 9:14 AM 9/16/2006
