S13 AUTO TO MANUAL transmission SWAP
W805
Car: 93 240SX
i have a 93 240sx coupe with a dohc. the automatic transmission went out so i am going to do a manual swap. these are the parts that i have to do the swap:
manual trannydrive shafts off the manual donor carflywheel clutch interior trim around shifterECU off a manual 240sx dohc
is there anything else i need for the swap to work?is there anything specific that i should know with wiring, ignition, peedometer cable, etc?
any help hould be greatly appreciated!
xekushnr
Car: '90 Nissan 240SX Hatch
brake pedalclutch pedalmaster cylslave cylclutch cablegearboxhydrolic lines
im probably missing other parts too, this is just all i could think of
W805
Car: 93 240SX
yeah, i have the brake and clutch pedal assy., clutch master and slave cylinder with the lines and all.
also, will i have any problems with the pilot bearing/or pilot bushing?
NISTECH
There is a very comprehensive install write up on this exact subject in 240 vert forum.
W805
Car: 93 240SX
thanks for all the help! im going to go ahead with the swap later on this week. if i run into any problems ill let you guys know.
