kauaiboy25 »
https://forums.nicoclub.com/kauaiboy25-u154682.html
Thu Apr 01, 2010 4:18 pm
before the flames begin to burn, this is NOT another how do I question.
so, i sourced a pair of seat belt assy. from a 1993 Isuzu Rodeo. and now i have a problem and possibly a solution (this is where my question is). The bottom bolt of the assy fits just fine, but the top does not. i came up with 2 possible solutions and want your opinion on it.
1) make a horizontal bracket and bolt it up...see pic below:
--no, i wont use a piece of metal that thick...
2) make a vertical bracket, cut tab off the assy.(circled in red) and weld the piece of metal to the bracket so i can use the original hole the screw went in:
3) get S14 seat belts and call it a day
so now i need your input. if you guys think the bracket idea would suffice, what metal thickness should be good? and if you suggest i get s14 belts or what ever, do u have some for sale?...i ask because the junk yard on my island sucks!...seriously, i been searching the junk yard for months and so far this is the best i could come up with..
thanks in advice
