s13 anybody has this set up 18x8.5 30f and 18x9.5 12r please show pics
lalito
Car: 92 240sx
i just want to see pics of this set up or something similar...i have 18x 7.5 now, but iwant to buy wider wheels the FNOR-C..................here is a pic of the wheels i have now....thank you
whiterps13
Car: white LE hatch
18x9.5 +12 is going to require some serious rolling/pulling. if you want to leave your fenders alone, try a differant size.
naed240sx
Car: .....
No, the rear 9.5's should be fine, as long as he runs some stretched tires or camber or a little bit of both. Rolling would be neccesary, but not pulling. the fronts will not clear coilovers.
lalito
Car: 92 240sx
thanks guys , anybody have any pics of this setup? 18x19.5+12 rear on a s13 ...thanks again
McRussellPants
Car: 92 240SX
18x9.5 -13 I think.
18x9.5 +12 with +30 over fenders
To do a 9.5 +12 you'll need 2.7 camber and a 15mm pull with a 225/40 tire.
PS... 8.5 +30 goes in the trash can... do 18x9.5 all the way around.
whiterps13
Car: white LE hatch
i rest my case. look at the job that silver car needed to fit those. it looks like a got a little carried away with pulling, and pulled a hell of a dent into that 1/4 panel.
chmercer
he has spacers on there, about 30mm worth. 18x9.5 +12 takes far less pull.
nismofly
Car: 89 Nissan 240SX Hatch
are those the emotions off the white kouki with the yellow headlights thats in the pics next to yours from a while ago chmercer?
chmercer
yep yep, he was borrowing them for drift spares that day.
