S13 and Sentra brembo brakes
TogueDrifter
Car: 91 B13 SER
Are the brakes on a SER SpecV interchangable onto the S13?
Nismo_Freak
Car: 89 Nissan 240SX
Doubt it, measure the caliper.
TogueDrifter
Car: 91 B13 SER
Sorry I should have specified. I ment would the brembo brake package off a SERspecV fit onto the lug bolt pattern on the s13? If the Lug bolt pattern is the same than I believe I can fit the front calipers and rotors on with my 17's.
barrigas14
yes they are bolt on. unlike the G35/350 brakes they require no modifications...well drilling 5 lug if you have that. also you have to use 17" rims.
TogueDrifter
Car: 91 B13 SER
Yes I do have a pair of 17" rims on now. Oh, does it matter If the sentra's braking system has ABS, and my S13 does not?
barrigas14
no, it is just the brakes that you are swapping. but you might have your brake pedal feel "squishy." some guys that do the Z32 brake swap get that but some don't. bigger M/C will help with that. but other than that, it should all bolt up.
oh forgot to say that you need brake lines if you didn't know that already.
TogueDrifter
Car: 91 B13 SER
I was gonna replace the M/C with an OEM...The brake lines should be S13 or Sentra? My guess would be S13.
barrigas14
i actually
TogueDrifter wrote:I was gonna replace the M/C with an OEM...The brake lines should be S13 or Sentra? My guess would be S13.
i actually don't know...cuz i didn't ask...but i think you use the Z32 brake lines for the conversion. if you want to find out check out freshalloy and a guy over there uses the G35/Z brembos and it should be the same brake lines.
TogueDrifter
Car: 91 B13 SER
where is this "freshalloy"?
S14Life
Car: b5 s4 stage 3, 2001 pathfinder, 91 s10
TogueDrifter
Car: 91 B13 SER
thanks
Newcastle82
Car: sold my s13, have no car.
____________________
Bad idea, bro. Larger calipers in front require a larger amount of hydraulic fluid to properly compress them . I've got an s13 that I installed 30mm z32 calipers and rotors onto, and with the stock M/C, the brake pedal is an on/off switch. Very spongy about halfway down, and with any more than medium pedal pressure, you lock your brakes up.
Go with the 1 1/16" M/C, or at the very least, the 15/16" Nabco cylinder. Bolts onto your stock brake booster and with a tiny bit of modification to the way the lines are routed and installed into the cylinder, you'll be VERY happy you did.
TogueDrifter
Car: 91 B13 SER
1 1/16 or 15/16... what's oem? Where can I get this Nabco cylinder?
