S13 and s14 MT driveshaft same length???
slowpock
I was wondering if i could use an s13 MT driveshaft on my s14. Im doing a transmission swap. or if theres a way to make the AT driveshaft work
lonelywanderer
Car: 91 240sx coupe
the non abs s13 ones should work with a non abs s14
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
NO.
The S13 chassis is SHORTER than an S14, and the driveshafts are in NO WAY interchangeable.
If you saw them side-by-side, you'd really understand why...the S13 has a weird rubber bushing at the rear of the trans, S14 does not. Plus the length difference...
- Brian
