180fan »
https://forums.nicoclub.com/180fan-u3602.html
Wed Apr 20, 2005 7:48 pm
The head, I believe will bolt right up. The water pump design is different with the S14 than the S13 counterparts. If I'm not mistaken, so is the oil pump design and the block that the oil filter and the oil pressure sender unit goes to as well. The redtop and the blacktops have a difference in the actual oil pickup thing. The blacktops have a better design compared to the redtops. Otherwise, they should be pretty much the same.
