S13 and S14 5 speed swap parts?
Miller White
Car: 1989 240sx
Anyone know if you can use any of the s13 5 speed swap parts on an s14? Pedals? Slave and Master cyl? Drive shaft?
Dazzla
everything will work even the transmission...only thing you need is a s14 driveshaft and a s14 speed sensor m/t
pella
Car: 1995 240sx S14
what about the whole drive train???
sorry, was looking through the archives and found this. its the closest thing ive found so far. my car is a 95 and has a blown headgasket with an auto trannsmission. my friend has a 92 but just had the motor and (5 speed) transmission pulled for a 350 swap. hes gonna sell me everything he cant use but the drive shaft for $700. dont wanna pass on this but need to know.
biggie
You would want to keep the wiring/ECU S14 and swap the S14 intake mani over to the S13 engine (connectors, etc are different). May need to drill the top of the transmission to install crank angle sensor. S14 MT speed sensor needed. And distributor swaped from S14 engine to S13 engine.
pella
Car: 1995 240sx S14
biggie wrote:You would want to keep the wiring/ECU S14 and swap the S14 intake mani over to the S13 engine (connectors, etc are different). May need to drill the top of the transmission to install crank angle sensor. S14 MT speed sensor needed. And distributor swaped from S14 engine to S13 engine.
Thank you. so now i have a start... i have heard that there is someware on NICO that sells DVDs on swaps and what to do. do you kno where? that would prob be easier than asking question that have benn asked a million times.
biggie
Go to the search at the top and type in "Swap DVD", should bring up some threads for them.
There is also a sticky at the top, here's the thread:zerothread/296577
Lonismos14
Car: 1995 Nissan 240sx, 1999 Chevy Hoe, 1996 Saturn Sl2
Sorry to thread jack but biggie what do you think of that greddy resovoir that i posted in the overheating thread in da kat section?
