S13 alloys and S13 steelies, same tires?
trpower7
I recently shod my stock S13 steelies in new rubber, only to find a perfect set of alloys at a yard near me for $75. The question is, will the rubber transfer over, IE do the wheels take the same size tires.
rschwalbe
Car: Weightlifting and my daughter
Not sure, but couldn't you measure the alloy rims and yours and see if they are close in size?
encasemyheart
yes, they both are 195/60-15, or 205/60-15 if you want.
Double check your current tire size, but this is the SE alloy wheel size, it should be the same size.
trpower7
aaahhhh, brilliance :)
1dollar240
Quote »yes, they both are 195/60-15, or 205/60-15 if you want.[/quote]
correct, i'm running 205's. Gets a lil' extra rubber on the road
