ashibah83 »
https://forums.nicoclub.com/ashibah83-u48930.html
Tue Mar 18, 2008 2:38 pm
as said before, some of the specs cant be set right with stock parts when you have lowered the car, and even the stock ruca's will sometimes yeild no change, most alignment techs(i do ALOT of aligments) tend to Toe-n-go on most vehicles, meaning they will ONLY set the toe unless its obvious that camber or caster is out and most of the time they wont even touch the caster if its even adjustable( its not on most vehicles, except trucks and older cars), with aftermarket tension rods they should be able to get a cross caster of .3-.6 degrees higher on the passenger side(so the car doesnt follow the crown of the road) if you watch them and give them specific specs then they may be able to set it to your liking,but most places will tell you that if the readings are in specs then thats as good as its gonna get
i have full adjustable arms all around and i set mine to
-1.2 front camber both sides+.02 front toe(total)6.75 and 7.25 front caster
-1.5 rear camber0 rear toe
it was a pita getting all the specs where i wanted them and it took multiple trys(the car has to settle a little)but it acts exactly how i want it to when i track it, i think the only thing ill change is the caster, increase it, when i take it to drift events( positive caster=steerback)
