Richk14 »
https://forums.nicoclub.com/richk14-u134934.html
Thu May 28, 2009 8:22 am
1993 Nissan 240SX HatchKA24DE, 5spdKYB Struts
I recently did the 5 lug and z32 brake swap on my s13.
S14 FLCAs/spindles/hubsZ32 Front and rear calipers/rotorsZ32 Rear hubs
I also acquired a set of wheels from a buddies totaled '05 350z. Theyre the 18" touring wheels.
When the install was complete, i noticed i had some alignment issues. The front wheels were extremely toed out and the camber was a bit out of whack.
I took it to a local shop to get aligned and they wanted to charge me $180 for camber bolts, so i figured i'd do a bit more research to see exactly what needs to be done.
FL Camber was -.1FR Camber was -.4
Toe and caster were out of specs as well, but i dont have numbers to give you.
Does anyone have any input as to what i need to get to get all the alignment specs within tolerance?
I dont have any specific numbers in mind, but something pretty aggressive, the 240 is my play toy and not my daily driver so i dont mind if the tires last or not. The car will be used for spirited driving and some drifting here or there.
-RK
