s13 air filter
a30mayne
Car: 1994 Nissan 240sx Vert
Ok so I replaced my air filter about 2k miles ago and I noticed a dark burn spot. What can this be from?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Notice on your stock intake the tube that goes from the valve cover to it? That recirculates blowby gases back into the intake. You can rather put a breather on the valve cover (which I don't recommend, because its routed that way to meter blow by gases) or put a catch can in between. I would look into your pcv valve first though because if the pcv valve isn't working properly, it can cause this.
ricebike
2002 Quest
2005 Altima
not really the case:
if you still have the AIV pipe from your exhaust and is plumbed into the airbox, like mine, the AIV one way reed valve is starting to weaken/ carbon buildup & is backfiring into your intake
quick and easy remedy:
if you don't have this AIV valve in your vehicle, then revert back to what compactfean stated :whistle:
compactfean
daily
Sweet info ricebike!!! Totally forgot about the air injection.
