DOOM240sx wrote:Maybe i wasn't clear....basically the bulbs are in the sealed beam encloser.....now the problem i am having is with the whole assembly....when u take out the sealed beam encloser it's held on by a thin metal bracket and 4 screws.....this is what im speaking of when i say "the metal ring that holds the light in does not fit around the new lights" but thanx for the input....anyone else?
thanxDOOM
I had to "stretch" my metal ring out a bit. Once it actually goes on (it's a tite fit), it will stay on.
Easiest way for me is to bolt in the bottom two pieces so they fit, then wiggle the top part in like S13ChucKAT said. It will fit, or should, just use a little elbow grease, it shouldn't break anything
