raptor727 »
https://forums.nicoclub.com/raptor727-u83521.html
Thu Apr 01, 2010 2:23 pm
the other day i tried turning my ac on and nothing happened. no lights on the climate control were on at all nothing. i could turn the blower on at different speeds and couldnt control the blower direction. anyways checked and ended up the fuse blew. replaced it. everything works fine but as soon as i turn the ac on the car idle jumps on and the ac kicks on then the fuse blows. and it worked before. i tried putting a higher fuse in and going from the stock 10amp to a 25amp and the 25amp fuse does not blow, and ac works etc. but i am not going to run that high of an amp fuse due to the chances of fire etc. s13 sr20det with ka24de compressor. three of four bolts in compressor, compressor is solidly mounted and lined up correctly etc. any ideas?
