S13 ABS removal
demos_sav
Car: Nissan s13 200SX CA18DET
I need to remove my ABS unit on my S13. I have searched and found that the easiest way to do it is by buying a tee brake fitting to merge the F line to FR and FL, and a coupler for the rear line. What I want to know is what size fittings do I need to get?
http://www.sturdybuiltonline.com/a**...ttingTee-2.jpg
This is the tee
http://www.centrevilletrailer.com/pa...railerpart.jpg
And this is the coupler
airman86
Or you could just pull the ABS fuse out.
After spending ~5 minutes googling, it seems like the pitch is M10x1. But you can verify all that yourself!
demos_sav
I did remove the fuse. Bue since this is my drift build I need all unnecessary weight removed. I did search in google and couldn't find it. Thank you very much
