pmkls2 »
https://forums.nicoclub.com/pmkls2-u8760.html
Thu Mar 19, 2009 10:54 am
Most popular R134 conversion kits contain refrigerant and oil that is compatible with the original R12 oil and seals and mixes just fine. Also, there are a few things that one needs to know when converting and/or servicing a/c systems. First, when you convert to R134 fron R12 you only charge the system to about 90% of the specified system capacity. Any time that you recover and recharge the system it needs to have a vacuum pulled on it to ensure that all of the air and more importantly moisture is removed. R134 is less efficient than R12 so when doing a conversion the system will not perform as well as with R12. As far as how well the system on a s13 works, its mediocre. I converted my sohc several years ago when it ran low on R12 simply because my shop quit selling R12 completely. I have removed my belt driven fan and have a dual electric fan setup along with the original condenser fan and I have it wired so that all 3 run with the a/c compressor on. Even with the battery of fans I have on the car the a/c sucks in heavy traffic. However, on the open highway the a/c will freeze me out of the car. To cut to the chase, it is probably best to have somebody with a/c service equipment charge the system and the a/c on these cars works ok, but I've seen worse.
