lightning2000 »
https://forums.nicoclub.com/lightning2000-u157889.html
Tue Apr 06, 2010 1:09 am
I know this is only my second post so a quick hey, how you doing.
Now on to the issue at hand. Bought my car without a/c and am putting it in. I have everything in except the condenser fan which I have on the way. I do have 2 plugs missing though and want to check and make sure a couple things. The first plug missing is the one that connects to the condenser fan. I have a brown/white wire and a black wire cut next to the fan relay. From looking at a wiring diagram these appear to be the ones for the plug. Is this correct? If so is there a difference between this plug on an s13 and an s14 chassis? Finally with this plug...does anyone have a crap wiring harness that still has this plug on it PLEASE!!! It's 90 degrees already during the day and I prefer air as this is my daily.
The second plug is the one that goes to the compressor. I know its the green/blue wire but what is the connector. I have seen on an s14 it is a simple female connector and wanted to check if this is the same on an s13.
Thanks for the help.
