I_eat_hondas »
https://forums.nicoclub.com/i-eat-hondas-u2402.html
Sun May 07, 2006 12:47 pm
Ok so here we go again.... I am desperately trying to avoid taking my transmission off, but Im running out of options. The car shifts in and out of gear when the motor is not running. If I put it in gear and start it with the clutch in , it bucks like the clutch is not disengaged. starting in neutral is ok but it wont go into gear. The slave seems to work just fine (moves about an inch and a half to two inches) and the release fork does not wiggle around inside the bellhousing at all. This is a spec clutch that is almost brand new. It has less than 500 miles on it. I have tried everything short of replacing a brand new clutch. Someone has to have some insight for me.
