:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Fri Feb 27, 2004 5:37 am
Yes, it works.
To put S13 motor into S14 or S14 into S13: Use head and block only, use all accessories currently on the chassis.
Differences:
Valve cover (they DO NOT interchange)Distributor (use the one that came with the chassis)Front timing cover (use the one that came with the motor)
Otherwise, S14 intake mani can go on a S13 motor, and S13 mani on S14...but to make it easy, just use the one that was originally in the engine bay of the car recieving the new motor.
Same for exhaust manifold...that bolt on to either motor, but te manis are different, and the pipe that lead to the cat (from the mani) are different for S13 and S14...
Hope that helps - Brian
