Scooby24 »
https://forums.nicoclub.com/scooby24-u31746.html
Sun Oct 02, 2005 4:38 pm
You will get a CEL.
You need an S14 speed sensor. You need to jumper the top connector near the fuse box in the engine bay. If you want reverse lights you'll need to get pins 3 and 8 on the one with like 8 wires coming from it by the fuse box.
You need to shim the clutch pedal away from the firewall to keep it from hitting the floor. I tack welded big nuts to the end of the pedal and drilled out the studs and put in longer ones to have them clear the master cylinder.
You need a 1995 manual driveshaft...can't have any other year. (which I have if you want)
any other questions just ask. I just got everything finished friday and she runs great!
