PMan_S13 »
https://forums.nicoclub.com/pman-s13-u3715.html
Tue Oct 26, 2004 2:08 am
I am in the middle of dropping my built S13 KA24DE-T with s13 5 speed into my new S14, which is an automatic. I am also swapping to a s14 5spd driveshaft and I am using my VLSD from my hatch. Also, at least for the time being, the car will be running off the '95 auto ecu. If it doesn't work I will have to find a 5spd ecu to swap out.
Now my only concern at the moment is that I am wondering about the wiring from the transmission. It looks like it is very different, especially since it is an auto. So I am going to have to splice all the wires in it looks like. My question is this. The only wiring I need to accomplish is the following, correct?
-Short the park/neutral switch, so the car thinks it is always in park/nuetral so I can start it.
-Somehow wire up the speed sensor so my speedo works
-Wire up the reverse switch so that when I put the car in reverse the reverse lights come on.
Are those the only things I need to wire up? Because there is still the Neutral, 4th gear, and 5th gear sensors on the s13 5 spd. These are not needed for the car to run correctly, right? I'm not sure what purpose the nuetral switch has on a 5 spd anyway, but I believe the 4th and 5th sensors are only for the rpm govenor, so you can go over ~120 mph.. not necessarily a bad thing not to have connected,
You guys have a lot more knowledge in the more complicated bits, so I figured I'd ask the professionals =)
Thanks...
