S13 5-Speed into a S-14 Auto
92gvr4#333
Can I use a S-13 transmission for my Swap instaed of a S-14 transmission? I beleive the bolt patterns are the same on the bell housing but as for the mounting points and the lengths I am un-sure.
Anand
Car: 95 Nissan 240SX
is your S14 OBD1 or OBD2?
95 red 240
i was wondering the same thing. I have a obd-1 car. Would a s13 transmission work? Thanks for your help.
92gvr4#333
ODB 1 I am going to assume that it will seeing how the ECU won`t see any difference in the sensors.
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
obd2 s14's have a sensor on the top of the trans bellhousing that will not be there on the s13 that could cause ecu codes to be thrown.. maybe worse ... im not exactly sure what it does.. i threw mine away
