s13.5 radiator question
EODguy036
Car: 1992 240sx hatch
so im working on getting plans into motion and parts installed on my 240, when i came across this little delima. may sound like a stupid question,but here goes. will i be able to mount my isis rad for my s13 ka24de back on after i do my s13.5 front end? the core support is from an s15 so i didnt know if it would still mount correctly.
thanks guys
Chris28
Car: 92 s13 KA-T
Whether or not your radiator will bolt back up is the least of your worries if you are doing a front end conversion. I'm pretty sure the mounting points are the same, but if not it's nothing a little fabrication can't fix. After doing the swap you'll be fairly well versed in fabrication.
sci2000tech
Car: '92 Nissan 240SX S13.5 RB20DET 'Vert
Worst case scenario, you just have to fab up some new brakets.
I didn't use the s15 core support so I'm not 100% sure on the differences, but I doubt it would be much work to mount your s13 radiator.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
If you use a S15 core with mated S13/S14 tension rod brackets then you need a S14 radiator
EODguy036
OutToWinPAHC wrote:If you use a S15 core with mated S13/S14 tension rod brackets then you need a S14 radiator
what do you mean by mated tension rod brackets? a little extra fab shouldnt be a problem. thanks guys
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
S13 tension rod brackets dont line up to the holes on the S14/S15 core. S14 tension rods dont bolt up to the s13 frame rail. So get a pair of both, cut in half, using the S13 rear section, S14 front section, weld and plate.
EODguy036
got it, thanks man. thats a big help, never would have thaught of that until i tryed to bolt em up. at which time i would have said the most comon words during a build..... "damn it!..... piece of s***"
