180fan »
https://forums.nicoclub.com/180fan-u3602.html
Thu Jun 15, 2006 6:29 am
people usually forget the cotter pins. 30mm socket for the nuts, the conversion brake lines, the rotors, grab the rear ebrake assembly if you're gonna be there and be sure to grab the ebrake lines all the way up to the one that meets up to the cable that attaches to the ebrake handle...if that makes any sense.
ebrake handle ----(cable from handle)---|======(the two lines that split off from the ebrake handle to the two rear spindles)
