S13 4 lug hubs into s14 4 lug?? help
mmaxeyjr
Car: 1995 s14
Will an s13 4 lug hub bolt to a s14 that is a 4 lug setup without any issues?
I have nismo extended wheel studs for an s13 and they obviously wont work in a s14 hub because the studs are different. So i'm trying to swap a s13 front hub onto my s14.
thank you
Beems240sx
Car: built S14, E30, R6 raven
i have an s13 rear 4 lug hub on my s14. no issues at all. not sure about the front but i dont see why they would be different
mech_E
Car: 97 240sx
They will not work. s13 hubs have an bearing ID of 30mm while the s14 hubs have an ID of 32 mm. Therefore, the s13 hub will not fit over the s14 spindle. Goodluck.
