S13 4 lug conversion into s14 240sx 5 lug conversion brakes!
puerkone
Car: 1989 Nissan 240SX SE-R
OK I have a whole set of 5 lug hubs and my question is, can I use my stock 4 lug brake calipers? or i need different 5 lug calipers? do i need the camber arms? or will the hubs automatically fit my S13?
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
You can use your four lug hubs. Calipers are just calipers and are not hub specific. The hub bearings are the same it's just the actual hub itself with the four and five lug setups which are different.
unibody_s13
Car: s13 blacktop
yeah u can use the calipers... no biggie! u can also check this out http://en.wikibooks.org/wiki/N...rsion
puerkone
wow great thanks just last question i still dont understand. With my S14 5 lug hubs can I put the 300zx brake calipers? will they flush with my S14 hub? S14 5 lug and 300zx 5 lug, do both use the same brake rotors? [
positron1
I believe so, I'm not familiar with the S14 but for piece of mind check this page. http://importnut.net/300zxbrakeswap.htm It has everything you want to know about these brakes.
Another all knowledge page from 94_240 How To: Ultimate z32 Brake Swap w/Lots of Pics zerothread?id=386360
unibody_s13
Car: s13 blacktop
puerkone wrote:wow great thanks just last question i still dont understand. With my S14 5 lug hubs can I put the 300zx brake calipers? will they flush with my S14 hub? S14 5 lug and 300zx 5 lug, do both use the same brake rotors? [
nope.300zx have a different ebrake assembly... Z32 and most GTR, GTS, GTST R32-R34 use "297mm x 18mm Rotor - Internal drum e-Brake", and S-chassis 88-98 uses "258mm x 9mm Rotor - Integrated caliper driven e-brake".
