95lstegman »
https://forums.nicoclub.com/95lstegman-u33967.html
Fri Nov 04, 2005 12:11 pm
you don't need to do the 5-lug swap to get Z32 brakes. you can put the fronts straight on the car after redrilling the rotors, and the rears will fit after changing over to the hub-integral parking brake.
if you still want more, 350Z brakes, skyline GT-R (R32 GT-R=Z32, R33 GT-R is larger, R34 GT-R larger still), and '97+ Q45 brakes will all fit right on with redrilled rotors. i'm not sure how humungous the R33 or R34 GT-R brakes are, although i think the R34 GT-R is similar or same as 350Z track w/ those nice brembos. lots of money there. my personal pick for ultra track duty are the '97+ Q45 brakes. 11.7" rotors, twin-piston calipers with more piston area than Z32 although not aluminum. if you can fade those you're a champ. and they look sexy .
but really you shouldn't need brakes that big. Z32's should be FINE, even with normal/street pads. and the 10.9" rotors will mean much less rotational inertia and unsprung weight, as will the aluminum calipers (get the aluminum ones!).
