Hello,
I was wondering if anyone got their stock tachometer of 89 90 240sx hooked up to the 2jzgte (I believe the 240 came with the DOHC tach since it had an SR before)? I am having the worst luck with it. I got the Dakota SGI-8 box hooked up. It flashes green meaning it has a signal (using ignitor pin AND NOT tachometer pin out as told). When hooked up to the gauge cluster, it is unresponsive. I tried both low and high voltage out, which covers the SOHC and DOHC gauge cluster.
Tach was taken out and inspected and the connection looked clean (nothing burnt). Has anyone have any experiences with the dakota box and hook up? Any advice would greatly be appreciated!
Also, speedometer....do I need to change out the VSS? Thanks!!!
After spending a couple more hours of searching, some ppl are saying use Pin 1 "Ignition Switch" (IGSW) Pin out. Is this THE ONE and NOT Pin 58 "IGF" (ignitor)
