S13 240sx rear rotors
Luchitosan
Car: Nissan 200sx Ca18det 4 port
Hi guys, i came from the Nico CA18det engine forum, and need your help.
I own a S13 200sx facelift (euro spec ca18det) need to replace the rear rotors
Someone can confirm if the S13 240sx rear rotors will work to replace it plug and play ? Because the parking brake.
Thanks yous, Salute.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
What type parking brake do you have?
Luchitosan
The oem, factory
compactfean
daily
I mean, does the caliper activate the e brake or do you have parking brake shoes? Also what diameter is your rotor? vented?
Luchitosan
Is with shoes system, solid rotor, i think is 258 diameter not sure .
compactfean
daily
The s14 rotors are what you are looking for than. S13 is not shoe style parking brake.
Luchitosan
Ohh, f*** me, i buy the wrong ones. Can you send me a link to know where to buy the right ones ?
Luchitosan
for example, something like this will work ?
http://www.ebay.com/itm/150777017613?it ... 4020wt_905
compactfean
daily
Yes. Notice how it has the section for the parking brake shoes to fit in. s13's don't have that. Also it uses a vented rotor. S13 rears are solid.
Luchitosan
Ok, thanks for the info it's very helpful to me.
Salute you. Lucho
