s13 240 with redtop sr20det only running on 3 cylinders help
reed857
Car: honda
as the title says.
went through and checked everything #4 is not getting a spark.
check plugcoilinjectorgroundand anything else I could think of
the only thing that I couldnt check for sure is the wiring. I didnt do the wiring but I dont have wiring diagram to look what part the wires are supposed to go to from the coil to the harness. help please... my car got stolen and I need to get my friends car running right so I can borrow it. thanks in advance.
here is a link to my old stolen car. sorry if I posted in the wrong place but I did search, I just didnt know what to search for. http://www.honda-tech.com/zerothread?id=1905292
nani
Car: 89-240sx
where did u get the motor from?
nani
Car: 89-240sx
wow sucks about your car man. hondas are the most stolen cars its unbelivable.
reed857
Car: honda
its my friends car not sure where he got it from. any idea about the harness? I switched the coils and the plugs to check and see if it was either one of those but they worked on number 3. so just use a multimeter ? what am I looking for. your talking about the the third wire that comes out of the coil? not the ground or the one that all of the coils connect to but the one that has its own 2 wires from the harness? anyoen have a pics of theres? if you could just follow the three wires from number 4 to where they go and what wires they connect to or better yet where the wires go from the harness to the coils. thanks. I think its a 6pin connector.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Moved to RWD SR!
