s13 17x8 fitment question
Nu2ThESc3N3
Car: n/a
i know a couple people have answered but i was a little unsure before i go and order these wheels, will the 5zigen FN01R-C's in 17x8 +35 will work up front on my 90' hatch and clear the breaks and at steering wheel lock will i get any rubbing ?
AZ89two4Tsx
Should work just fine. I run an 18x8 +37 (really close if not) up front. If it rubs, it'll be because of tire size. I'm assuming you're running probably a 225/50 or close?
x8 is no sweat. People run x9 all the time.
94_240sx
Car: 94_240SX
In your case, it's all about tires. +35 will sunken, so you want 10-15mm spacers to make it flush with the fender. I have 235/40 on 17x8 and tire rubs on fender liner, so I had to adjust the caster a little bit.
Nu2ThESc3N3
Car: n/a
ok, soo 10-15mm spacers to make em flush wit the fender, and how many degrees did you adjust the caster ? thanx again guys as im VERY new to 240's, i just jumped in and need as much help as i can get ... oh and as of right now i dont have any tire size im set on, ideas are more than welcomed...
94_240sx
Car: 94_240SX
Nu2ThESc3N3 wrote:ok, soo 10-15mm spacers to make em flush wit the fender, and how many degrees did you adjust the caster ? thanx again guys as im VERY new to 240's, i just jumped in and need as much help as i can get ... oh and as of right now i dont have any tire size im set on, ideas are more than welcomed...
Not by much. Tire was rubbing when I had stock tension rods, so when I installed aftermarket tension rods, I made it shorter approximately 2-4mm. Rubbing was not serious at all, but it bothered me, so I had to take care of it. I could have used a heat gun to modify fender liner too.
This is 17x8 +38 with 15mm spacer, so offset is +23. Tire is 235/40 Falken.
ashibah83
Car: 93 SUPA BLACK COUPE
why not just get the 17x9 +20's?
s13rb25det
Car: 92 240sx w/rb25det
discount tire stoped making the 17x9 in the 4 lug.
ashibah83
i didnt know discount tire made 5Zigen wheels????
and FRSPORT has them
Nu2ThESc3N3
Car: n/a
i want to do a staggered set up that is why i dont go 17x9's ... and as far as tension rods go, i already have tein tension rods on the car... also what are a good brand of spacers to go with ? again thanx for the patience wit the noob questions...and are those the nismo volks ?
Viet-Tam
Car: 1992 NISSAN 240SX HATCH BACK
17x8, +35 offset , 215/45/17. No rubbing what so ever
Nu2ThESc3N3
Car: n/a
arrite kool, thanx a lot, does anyone know of a good spot to get wheels from in NY ? there are a lot of shady shops out here ... and i dont want to go to some1 who is just going to try to F*** me for all the money they can get out of me...
