In an interesting life lesson I found out that all vh45de bottom ends are not the same, all the info I found said they were. On the version 2 aka oval port there are 2 different bottom ends, the differences are the crank (main bearing portion) and the main bearings.
Whereas a majority probably came with the same crank and main bearings s1 and s2 .the one I got ahold of had all the thin bearings for the mains, instead of the 3 size bearings.
Solution came by using vk45/vk56 main bearings, width, ID, OD where exactly the same size, plastiguage said it was good.
