twisted99s10 »
https://forums.nicoclub.com/twisted99s10-u66955.html
Thu Apr 11, 2013 7:23 am
I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated.
Rb25det s1
walbro255 fuel pump
nismo fpr
holset hx35 turbo
fmic
3" exhaust
freddy intake manifold
q45tb
q45 maf
